Mine on idle works around 48 -51 and under load around 77+
G Gono Distinguished May 30, 2009 3 0 18,510 May 30, 2009 #1 Mine on idle works around 48 -51 and under load around 77+
A AKM880 Distinguished Apr 16, 2009 2,330 0 19,810 May 30, 2009 #2 What kind of cooler/heatsink are you using? The stock one?
G Gono Distinguished May 30, 2009 3 0 18,510 May 30, 2009 #3 yea im using the stock one at stock speed
H Helloworld_98 Distinguished Feb 9, 2009 3,371 0 20,790 May 30, 2009 #5 those are normal temps for the stock cooler, don't worry, it can take 90C before it gets permanently damaged.
