the power light does not light. the led is good when tested. have reversed the connection and still don't work. if you take the ground pin out and touch ground it works. with a meter you get 4.95v from + to case - but nothing on the board pin. can you help me. it is an asus M2R32-MVP motherboard and still under warrenty but asus tells me not for that. they will not exchange it.
