Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > EP45-DS3L & OCZ 4GB Reaper memory problem?
Forum Motherboards & Memory : Gigabyte - EP45-DS3L & OCZ 4GB Reaper memory problem?
Spec:
Intel q9550 2.83 Ghz
OCZ Reaper 1066mhz 4gb (2x2gb)
XFX HD4890 1Gb
Old memory: Standard random 667mhz 3GB = (2x1gb) + (2x512mb)
First, sorry for my bad English. But i hope you guys can help me anyways.
I install my new memory for a few days ago, witch doesn't work properly. First, use slot 1 and 3 (yellow & yellow) = total fail. Black screen --> wait time --> reboot. (Not possible to pass to BIOS)
Slot 2 & 4 (red slots, witch i use ATM) the motherboard "boot screen" shows up for a few sec. --> reboot. (Not possible to pass to BIOS)
So ATM i plugg 1 512mb memory in slot 1. Can pass to BIOS and change the settings after this: (Only changed the stuffs for memory, not the CPU so all CPU settings are original. (I'm scared to destroy something)
Spoiler :
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto or fast
CPU Clock Ratio ..........................: 9
Fine CPU Clock Ratio.....................:.0
CPU Frequency ...........................: 3Ghz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 333Mhz
PCI Express Frequency (Mhz) .........:Set to 100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: <<< stock
PCI Express Clock Drive.................: <<< stock
CPU Clock Skew (ps)....................: <<< 0
MCH Clock Skew (ps)...................: <<< 50-150
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 2.40B
Memory Frequency (Mhz) ..............: 800
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5
tRCD .........................................5
tRP'...........................................5
tRAS..........................................12/15/18
Advanced Timing Control
tRRD...........................................3-5
tWTR..........................................3-6 (may need 12 first time)
tWR............................................4-6 (may need 14 first time)
tRFC...........................................52-64 (May need 68 first time)
tRTP...........................................3-5
Command Rate (CMD) ....................:2
Driving Strength Profiles
Driving Strength ............................800-1066
Channel A
Static tRead Value.........................:7-10
tRD Phase0 Adjustment...................:<<< Leave for all below as well
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Motherboard Voltage Control
Voltage Type.………... Manual
CPU
CPU Vcore….……….........................: Auto
CPU Termination…..... 1.200V*.......: <<< See below
CPU PLL…………………....1.500V*.......: << Please set to stock or less, Auto overvolts this way to much
CPU Referen.…………....0.755V*.......: <<< .64% Of Vtt (Termination above) Auto Will set this correctly
CPU Reference2………,,0.800V*.......:<<< .67% Of Vtt (Termination above) Auto Will set this correctly
MCH/ICH
MCH Core…………….....1.100V...........: << 1.2-1.3
MCH Reference….…….0.800V...........; <<< Leave
MCH/DRAM Ref.…......0.900V...........: <<< Leave
ICH I/O……………….....1.550V............: <<< 1.55-1.6
ICH Core…………...……1.100V............: <<< 1.1x-1.2
DRAM
DRAM Voltage ……....1.800V............: 2.0-2.1
DRAM Termination .…0.900V............: <<< Leave
Channel A Reference 0.900V............: <<< Leave
Channel B Reference 0.900V............: <<< Leave
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled] Enabled if you use Vmware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect ..............[Disabled] *Note* Must be enabled to flash from USB
I save this settings --> turn of the computer ASAP it has reboot --> plugg out my old memory --> start and it's now works great.
BUT now the big problem. If i shut down or restart the computer same thing happens again. the motherboard "boot screen" shows up for a few sec. --> reboot. So, Plugg in old memory stick ->go to BIOS and this window appears:
[img] http://pici.se/pictures/small/ewIl [...] ldjEeK.jpg[/img] so, i press F10 (save and exit) and do the same thing like before. Shut down the computer and plug the old memory out and start.
Can someone help me to solve this problem? So annoying to need to crowling around on the flopr just to start the computer.
Sponsored Links
First step is to put in one stick, in the slot closest to the CPU, go into the first BIOS page, and execute the "Load Optimized Defaults" function - it will 'read' the RAM, and set all the 'auto's you see shown. Without having done this, it's 'flying blind', and doesn't know what components it's trying to make function. Then add your other stick - should work; if you wanted to run four sticks, it would take another minor change, but two should work on trhe same settings as one...
Reply to bilbat
There are 751 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
