Hey everyone, up until just recently I was running on 2 gigs of ddr2 1066 RAM with zero problems whatsoever. The ram is a dual channel kit from OCZ. I had a little extra money so I decided to buy the same kit again, making it 4 gigs dual channel. After installing that, I get an APPCRASH error when I try to play games and just now got a BSOD. I am pretty much positive that it is the RAM I installed, because I have never had any problems before. I am running on Windows Vista 32 bit. Is it possible that my power supply just isn't good enough to power the extra ram? I really would like to get this to work, but dont know what to do! Any and all help is appreciated.
In BIOS set the voltage to OCZ specifications 2.1-2.2v (listed on the link you posted). BIOS defaults to 1.8v. Set the data transfer rate to 1066Mhz. and the timings to specs. too.
Message edited by badge on 08-08-2009 at 06:07:32 PM
Wow, Might I just compliment you on your speedy response and accurate information! Thank you very much! The Ram was set to 1.9v I got it set to 2.23v So that's all said and done with. The Speed was set correctly from before. And I haven't got the slightest idea on how to adjust the timings in my BIOS. I found where you do it, but when I go from auto to manual there is around 16 options that pop up in front of me. I know the meaning of none of them!
Message edited by Wiiings12 on 08-08-2009 at 06:29:37 PM
I take the timing statement back, I just did a quick google search and figured everything out! I can't thank you enough badge! I was planning on sending this perfectly fine RAM back! Thank you!
