Hello;
I just buikd my first computer i bought a bareboines kit from TD with a mobo HDD And CPU w/case.
And its was great up until i tryed to install a new graphics card (XFX 9800 GT) . The motherboard i have is a PNY 630i With a GeForce 7150 Video Chipset. I can plug in my Graphics card in to the PCIe slot just fine and i can even hook up my monitor to the card and get a picture. But when i try to install the drivers on the disk it tells me that there is no compatible hardware. i even went to XFX websit and downloaded the newest driver version and it still says no compatible hardware. and under the Device manager it does not detect it. But under the system devices there is a little (!) in yellow under the PCI Express Standard Root Port.
The Microsoft error is as follows: ''Your computer's system firmware does not include enough information to properly configure and use this device. To use this device, contact your computer manufacturer to obtain a firmware or BIOS update. (Code 35) Cause The Multiprocessor System (MPS) table, which stores the resource assignments for the BIOS, is missing an entry for your device and must be updated. Contact the system vendor to update the BIOS.'' I've spent weeks with PNY's motherboard support, which is lousy at best and they can provide no resolution and won't even admit it's their problem.
Ive tried everything i can think of.
IM running Vista Ultimate x32 bit
4gb Ram
550W Corsair PSU
So if anyone can help it would much appreciated.
4gb Ram
550W Corsair PSU
