How does this look so far? Does anybody see any problems with the current settings?
Seems to be stable on P95 after finally getting the right settings for the RAM. Besides the RAM all of the settings I arrived at by lowering my cpu volts to 1.35 (mobo set it at 1.45 default) and then just putting the multiplier up to a number ran P95 and if it survived like 10-15 I went to the next thing. If it didnt work I just uped the volts a step. Not the best way I know.
here is my system:
CPU - AMD Phenom II X4 955 BE (stock hsf)
MOBO - MSI 870A-G54
RAM - G.SKILL Ripjaws 4GB DDR3 1600
GPU - XFX HD 5830
Case - HAF 922
HDD - Samsung Spinpoint f3 1TB
Optical - Samsung SH-S223C
PSU - XFX P1-650X-CAG9 650W
OC settings:
Cpu - 3.8 MHz
x19 multiplier
200 fsb
1.37 volts
CPU-NB Freq - 2400 MHz
1.214 volts
HT - 2000 MHz
auto volts
RAM - DDR3 1600
1.536 volts
9-9-9-9-24 2T
SB and NB volts are auto
here is the temps during P95
------------TMP-------------
..................Min Max Average
CPU Core0 40.00 61.50 59.98
CPU Core1 40.00 61.50 59.98
CPU Core2 40.00 61.50 59.98
CPU Core3 40.00 61.50 59.98
TMPIN0 35.00 56.00 54.29
TMPIN1 128.00 128.00 128.00
TMPIN2 28.00 33.00 32.38
TMPIN3 0.00 0.00 0.00
Anything I could do without upping cpu volts any you think?
here is my system:
MOBO - MSI 870A-G54
GPU - XFX HD 5830
Case - HAF 922
OC settings:
Cpu - 3.8 MHz
x19 multiplier
200 fsb
1.37 volts
1.214 volts
HT - 2000 MHz
auto volts
RAM - DDR3 1600
1.536 volts
9-9-9-9-24 2T
