Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > I have a strange problem you might be able to help with
Forum Graphic & Displays : Graphics Cards - I have a strange problem you might be able to help with
Hi all
I have a strange problem you might be able to help with,
My system keeps crashing when playing games, some times with bluescreens and sometimes just frozen, so I have to force a reset.
I have had the system test with a GF-9800 and its runs stable, tested by the company I got the mobo and other parts from, I send the GFX card back to XFX and they say its 100% fine. I have tired the drivers from the CD that came with the card and the new ones from NV.
I got the card before I upgraded all the other parts in the system, but I did have the same problem as before AMD 4400x2 Gigabyte mobo. So i thought the problem was with the old parts. Guess I was wrong.
So I'm total stumped. I don't want to get a new GFX card this is still a very hight spec card.
System spec
Q6600
Asus P5Q, P45, Socket-775
XfX 8800GTS Fatality
OCZ DDR2 PC8500 4048MB KIT, Reaper HPC,
600W PSU
Windows XP SP3
------------------------------ Intel Core 2 Quad Q6600 2.4GHz
OCZ DDR2 PC8500 4096MB KIT, Reaper HPC,
Samsung SpinPoint S166 160GB SATA2
Sponsored Links
What kind of PSU do you have, and did you upgrade it as well?
Reply to jitpublisher
Its a 600W ATX.2 SLI Janetech. i know it handles a 9800 fine then it should be ok with 8800?
Reply to jagzc
what bsod do you get? note the codes and the titles,
like memory management / 0x00000C1 etc....
Reply to montyuk
normally had NV something I haven't had a blue screen in a while since i updated the BOIS.
Reply to jagzc
Could be a driver issue or it could be a memory issue.
The psu may not deliver enough amps on the 12v rail to power the gpu. Having enough watts isn't the only thing that drives a computer.
As mentioned, the codes and text from the BSoD will tell you what the cause of the issue is. Get those codes and go a google search or go to the mobo and gpu forums for similiar issues.
------------------------------ ASRock X58 Extreme - Core i7 920 - 6GB Crucial Ballistix DDR3 1600 - Sapphire 4890 2GB - Creative Xtreme Gamer - 4-80GB WD in RAID0 on HighPoint RR 2310 as OS drive - 1-320GB WD scratch drive - Corsair CMPSU 750TX - HAF 932 - Hanns-G 281DPB @ 1900x1200
Reply to chunkymonster
what kinda memory issue can it be if the setup has worked with another card ?
Reply to jagzc
Just offering ideas and possibilities to help you fix your problem.
Heat could cause game freezes and BSoD's. Got dust bunnies? Got proper ventilation? Are the temps in your case and gpu within limits?
Another possibility could be hardware incompatibility. Have you updated the mobo with the latest BIOS version?
I'd say heat issues. One easy way to test it is to open the side of your case and blow a fan into it then see if the crashes stop or at least get better.
Reply to jennyh
I am betting on the PSU. Under load, while gaming, the psu draws extra power.
Reply to geofelt
+1 on the PSU. I had similar occurrences as you a few years ago, and replacing the PSU fixed it. Even though it might have enough wattage and amperage, it very well could still be faulty. Such as not putting out as much power as it claims to be able.
Reply to efeat
Yea that was my first thought to and opend the case and all still crashed
Reply to jagzc
Can i ask you what parts you had at the time? The only thing i wonder about it not being the psu is that i had is tested by a company and a new gfc card games and bench marking and it was fine over the few days they has and the was a 9800 that would draw more power?
Reply to jagzc
did you remember to completely uninstall the drivers for your previous card prior to removing it and installing the new card?
could just be some left over trash from the older card causing problems.
look up a program called drivesweeper to clean out the gunk.
Reply to montyuk
It ws a new Hard drive and all. Everything was new bar the GFx card and the PSU
Reply to jagzc
Re-install the driver again one more time , remove the old one first.
Check pre-requiste for XfX 8800GTS Fatality in amps on the 12 rail volt. compare that to the pre-requiste for the 9600.
I take a look and the specification for youe psu and I think 19A on the 12v rail it's not a lot. Maybe someone with more experience on Psu can help you more. But I will look on that way for sure.
Reply to jive
After a lot of help from people i think it might me my PSU so i have been looking a new one. After all why the hell not its an old one and a *** make after all it was a gift
Corsair Powersupply 650W Black, ATX/EPS, im guessing that will do it fine as i dont plan on sli. and i only have one HDD for now but will never had more then 2 inside.
Reply to jagzc
Reply to jagzc
There are 1154 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
