Tom's Hardware > Forum > Windows XP > Configuration & Customize > Problems with Xp and several programs
Forum Windows XP : Configuration & Customize - Problems with Xp and several programs
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I have a machine with xp home on it. It will not run
msconfig,regedit and ie will knock me off the internet
after 3 to 10 web sites. I have also tried running IE
repair which is not listed add remove programs and tried
doing the run command to do this which wouldnt work.
I have scan for viruses and spyware. which it had. After
cleaning it up still does the same thing. I have tried
reloading Xp upgrade. Any other Ideals?
Sponsored Links
IE6 is no longer in the general Add/Remove Programs
section.
Microsoft moved it to the Windows Components section.
>-----Original Message-----
Reply to Jeffo
- 0 +
On Mon, 10 May 2004 14:00:47 -0700, menejd scratched out the following:
> I have a machine with xp home on it. It will not run msconfig,regedit and
> ie will knock me off the internet after 3 to 10 web sites. I have also
> tried running IE repair which is not listed add remove programs and tried
> I have scan for viruses and spyware. which it had. After cleaning it up
> still does the same thing. I have tried reloading Xp upgrade. Any other
> Ideals?
You are still infected. Go to the virus group and get help
Reply to eddie
There are 1267 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
