Will this new build work?
mobiusrm
55
Hello, new to forums and new to building comps. Well anyways I am going to build a new rig when windows 7 comes out, so I do have some time to change some things around and all. I was wondering if this config will work. Or maybe I can save a little money some where. I do want to build a solid performing gaming comp so I do expect to dish out some money for it. If you have any doubts about the system or better ideas please let me know. Thanks.
Thermaltake Armor Series VA8003BWS Black Full Tower Case w/ 25CM Fan - Retail
EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
stock heat sink
or
Noctua NH-U12P SE1366 120mm SSO CPU Cooler - Retail
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C9 - Retail
or
mushkin 3GB (3 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Triple Channel Kit Desktop Memory Model 998583 - Retail
EVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
most likely
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
or
SILVERSTONE DECATHLON DA850 850W ATX 12V 2.2 & EPS 12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
or
OCZ GameXStream OCZ600GXSSLI 600W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply - Retail
x2 Western Digital Caviar GP WD5000AACS 500GB 5400 to 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
or
x2 Seagate Barracuda 7200.12 ST3500410AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
LITE-ON 22X DVD Burner with LightScribe Black SATA Model iHAS422-08 - Retail
Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels PCI Interface Sound Card - Retail
ENCORE ENLWI-N PCI 2.3 Wireless Adapter - Retail
BYTECC Black 1.44MB Internal Floppy Drive Mac OS 8.6/9.0/9.0.2/9.0.4/9.1 Win 98/2000/ME/XP/Vista - Retail
SAMSUNG 2220WM-HAS Black 22" 5ms DVI Widescreen LCD Monitor with Height Adjustment 300 cd/m2 1000:1 Built in Speakers - Retail
or
Acer H213H bmid Black 21.5" 5ms HDMI Full HD 1080P Widescreen 16:9 LCD Monitor - Retail
and as I said windows 7
thanks again for any info.
boulard83
1,250
PSU : go with a Corais or PC-P&C-OCZ (TT, seasonic, Antec, are good too)
there is a PC-P&C 610 in deal right now.
HDD : 7200 rpm 32mb cache. the WD 640 are cheap.
COOLER : your I7 can run 3.8-4.0 on air with this cooling solution (noctua) !!
RAM : i think mushking make DDR3 1600 with 7-7-6 timing for quite cheap. 3 or 6 gb
GPU : nice one, GTX285 if budget is ok ;)
FLOPPY : ??????
Have fun :D
mobiusrm
55
Thanks for the input. I really like the corsair psu you mentioned. Its much more suitable for my build. I choose the silverstone with sli in mind, but you know I will probably never do it. Thanks again for the great ideas everyone.
