Need Audio Card help
Last response: in Systems
- NEED HELP! D: no audio output etc from HDMI graphics card Forum
- Need help getting an audio card and headphones Forum
- Need help with finding a decent Audio card. Forum
- SolvedDo i need sound card for front panel audio to work? Forum
- SolvedNeed help with High Defintion Audio Controller failed. Forum
- Need help with audio for HD 3870 & choosing between 2 gfx cards Forum
- SolvedSplitting Sound Audio need help bad! Forum
- SolvedNeed Help: Audio is constantly crashing Forum
- SolvedDo I need to disable onboard audio after installed a dedicated sound card? Forum
- SolvedNeed opinions for the Sennheiser PC 360 & mixamp/ Audio card setup Forum
- SolvedWindows wont let me install the drivers for my pro audio sound card. Please Help. Forum
- SolvedNeed help with rca and digital optical audio Forum
- Solvedwell i need to know r9 290x the one has inbuilt true audio , is it a replace of sound card ?( for sound enthusiasts) Forum
- Skippy/crackly audio. Speakers likely not at fault. Do I need a new sound card? Forum
- need a good graphics and audio card for compaq cq5700y Forum
- SolvedNeed Help in Front Panel Audio Forum
- SolvedNeed help with audio not working. Front audio ports and unplugging and re plugging noise. Forum
- SolvedAMD HD Audio 7850 disable! need help Forum
- Solved5.1ch audio - do I need sound card for 5.1ch Forum
- SolvedNeed help with my Audio Forum
- More resources
