I have an 80GB ATA drive, I have just installed a 250GB SATA2. Does it make any difference that the ATA is showing as slave? My OS is on the ATA slave drive. Is there any way to make this the master? Does it make any difference (performance whys) that it reads as slave? The computer loads and runs ok (so far).
edit, The ATA jumper is set to cable select. Drive is hooked up to first connection on IDE cable.
