i think this is the right catageorie but how do i increase the speed
of my fans i have intell fan over my processor but i think it is moving
to slow i need help with this one, is there anyway i can increae the
speed of the fan?
speed of the fan?
If it's the Intel PWM fan that comes with stock heatsink then you just go into BIOS, depending on what the menu says you select something similar to 'PC Health' and disable dynamic fan control for CPU from there and thereby forcing it to run 100% at all time.
------------------------------GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
Reply to wuzy
