Hi dear experts ;-)
excuse my bad English, I'm from Germany, I hope I can make myself understood...
My problem:
- I use(d) the Program "Active Partition Recovery" ( v.5) to recover a RAID 0 (976 GB, = two "dynamic" 500-GB disks).
- It has (had) 3 partitions. Unfortunately I formatted the Disk (fast-mode).
- I addes/fixed 2 new HDs (500 GB each) to be able to save the recovered partions and installed 3 partitons of the same original sizes (J: - K: - L: )
- To recover the partitions I used the program "Active Partition Recovery"
First I did a "Superscan" (took a very long time, 2 days and nights)
Result: It recognized the lost 3 partition (state: "good")a
- Then I saved the Superscan and tried the "Recover"- function, but the
programm always suggests drive letters of drives (e.g. M: and others N., O:, etc), however there is no drive M : !!
It then says:
Device Type is not supported"
"Disk has no MBR, or Sector Size is invalid, or Media Type is not
supported (CD-ROM, Floppy, Remote, etc).
"Supported only Fixed and Removable disk media types"
- Why doesn't it use my new disks/partitions/drives (J: - or K: - or L: ) ???
- Problem: I did the Superscan successfully, but find no way to recover
the partitions....
Anybody here who can help???.....
My problem:
It then says:
the partitions....
