Hello i verified 4.6v on green wire at plug and if jumped the ps turns on
so i assume ps is good. so i assume problem is the board or switch. button checks out but i'm only getting 1.6v at the switch.strange.
i plug in a diff p/s and get 3.6v at switch and p/s turns on.i'm assuming the 1.6v at switch from the stock p/s is not enough to turn it on.but why am i getting only 1.6v at switch when the input is 4.7? and not with the other p/s?
does the 5v input power other things then just the switch that might be pulling too much for an aging p/s and causing it to drop to 1.6v?
thanks for any help
thanks for any help
