I want to buy the HD4850 palit version which has a dual slot cooler. I was wondering whether my power supply would be good enough as buying the card along with power supply will be too costly. I have a Umax 450W power supply which came with the case. It has 25A on the single +12V rail.I also have an AMD phenom 9550, 250GB HDD, 2 case fans and a DVD writer. I don't want to OC the graphics card or the processor.
Assuming that the specs on your PSU are honest, and it really can deliver 25A continuous on the 12V, then yes, you'll be OK, at least temporarily. You can't ever be sure though, on those low budget PSUs.
------------------------------Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
You say your PSU came with your case. Chances are excellent that it is a POS and will NOT be able to reliably power a 4850, possibly dying in the process. When cheap PSUs croak, they usually take other parts with them. This PC Power & Cooling PSU, http://www.newegg.com/Product/Prod [...] 6817703017 , is a mere $50, and is 80+ certified. An Antec Earthwatts 430, http://www.newegg.com/Product/Prod [...] 6817371006, is $55. Either of those should be good; personally I'd buy the Antec because I have had only positive experiences with this specific product (and any Antec PSU I've bought over the last few years).
You would be much better served by dropping back to a 4830 if you have to in order to afford to replace your PSU.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
