notsonoobPCguy :
Hi, I recently got a new mobo its a MSi 870 G45. Its got this great OC switch thats super easy to use but it OCs the FSB and doesnt just change the multiplier, which i can't get above x15.5 anyways. Would there be another way to OC? Also do i need to unlock my CPU to be able to change the multiplier? It would make OCing a lot easier. Right now my CPU is at 3.5GHz but i don't want to keep OCing my RAM and FSB. -Thanks
I have the 770-G45 with the same switch.
MSI offer
OverClocking Tool on their website. I haven't used it, but it would be another option.
The other option is to edit BIOS settings yourself.
There's an item on the main menu called "Cell Menu", which lists a lot of options, including "Adjust CPU Ratio", which will allow you alter the multiplier (if your CPU allows it).
You may have to set the option "Advanced Clock Calibration" to Enabled, in order to adjust the CPU ratio, though.
Unlocking extra cores won't change the ability to change the multiplier, I don't think.
Check your manual for a list of the settings and what they do.
I would also recommend backing up the settings before you do anything to the BIOS, so that you can restore them if something goes wrong.
According to the MSI specs for your board, it includes something called "Auto OC Genie", which automatically selects the best OC settings for your system and sets them in the BIOS. So that's something you may want to look into, as well.
