Been following the forums for a couple weeks now and you guys have been extremely helpful to others (including a friend of mine). I was wondering if I could get a little insight on my planned system build, also. I just threw the part list together the other day.. won't necessarily be buying everything from newegg, but will definitely pick up a bunch there. A friend suggested using mwave.com for the processor/mobo/memory so I can get the hardware tested so I'll probably be doing that. For anything else I'm open to suggestion.. just looking to keep the whole build around $2,000 (plus/minus 200ish including shipping).
APPROXIMATE PURCHASE DATE: Within the next week or so
BUDGET RANGE: ~$2000
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Movies, Surfing the Net
PARTS NOT REQUIRED: Keyboard (Logitech G15)
PREFERRED WEBSITE(S) FOR PARTS: newegg, mwave (to assemble/test: mobo/cpu/memory)
PARTS PREFERENCES:
O/S - Microsoft Windows XP Professional SP2C 64-bit for System Builders - OEM - $139.99
Motherboard - GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail - $134.99
CPU - Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model BX80569Q9550 - Retail - $279.99
[strike]CPU Cooling - ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail - $36.99[/strike]
CPU Cooling - XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail - $39.99
[strike]Memory - Crucial Ballistix 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model BL2KIT25664BA1336 - Retail - $106.00 (x2 for 8GB - $212.00)[/strike]
Memory - G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBPI-B - Retail - $46.99 (x2 for 8GB - $93.98)
[strike]Video Card - EVGA 01G-P3-1280-AR GeForce GTX 280 1GB 512-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail - $334.99[/strike]
Video Card - SAPPHIRE 100251SR Radeon HD 4870 X2 2GB 512-bit (256-bit x 2) GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail - $424.99
[strike]Power Supply - COOLER MASTER UCP RS700-AAAAA3 700W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS SILVER Certified Power Supply - Retail - $189.99[/strike]
Power Supply - Antec Signature SG650 650W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply - Retail - $159.99
Harddrive 1 - Western Digital Raptor WD740ADFD 74GB 10000 RPM SATA 1.5Gb/s Hard Drive - OEM - $99.99 (for operating system)
Harddrive 2 - Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM - $69.99
CDROM - LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM - $24.99 (x2 - $49.98)
Case - Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail - $154.99
[strike]Monitor - ASUS VW266H Black 25.5" 2ms(GTG) HDMI Widescreen LCD Monitor - Retail - $369.99[/strike]
Monitor - Acer P243WAid Black-Silver 24" 2ms(GTG) HDMI Widescreen LCD Monitor with HDCP Support - Retail - $259.99
Total - [strike]$2,073.88 before shipping[/strike] $1,908.86 before shipping
OVERCLOCKING: No
SLI OR CROSSFIRE: Maybe in the future
MONITOR RESOLUTION: 1920x1200+
ADDITIONAL COMMENTS: No need for extra lighting (case has plenty), prefer to use XP64 so I can use more memory. The motherboard has good reviews on newegg, but I've heard stories from friends about gigabyte motherboards not supporting newer video cards. Will change if others have had similar problems.
Any insight is much appreciated. It's my second custom build but a first to be doing solo.
Thanks in advance,
Ryan
PARTS PREFERENCES:
OVERCLOCKING: No
Thanks in advance,
Ryan
