just now I cleaned my pc with a vacuum cleaner.. My problem now is I recently found out that it is dangerous to vacuum it with a big vacuum cleaner. What can I do now? Will my pc blow up soon? Are there any methods to remove the static charge?
Sponsored Links
I do it with a static-free brush to move the dust around and the vacuum head hovering above it to remove that unclinged dust.
Usually I don't wear an anti-static strap when servicing or mucking around as I use the casing as ground point, but when vacuuming I wear it. Works for me.
------------------------------ GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
http://farm3.static.flickr.com/2520/3850950213_aea6bbbcfe_o.jpg
Reply to wuzy
Will my pc explode? Right now it's working perfectly, all i can remember is I vacuumed the pc for a long time, almost every part. What will happen to my pc now? Is there any way to remove the static charge. Sorry I don't really get this static charge thingy.
Reply to esmerga
Quote :
Will my pc explode?
You mean like this?
Quote :
Have you tried something called searching?
Message edited by wuzy on 06-03-2009 at 10:41:18 AM
Reply to wuzy
Hi E
Just buy a can of compressed air, like wuzy I don't use a wrist strap either. Stay away from carpet and wear rubber soled shoes. After awhile grounding yourself to the chassis becomes second nature.
Reply to starams5
thanks people i will never ever use the vacuum ever again. and buy a compressed air can as suggested. Thanks again
Reply to esmerga
if you have access to an air compressor, it works better than the canned air, and provides a near infinite supply.
On a similar note, has any of you ever saw dust that looked like fur? without pets?
I recently cleaned a friends computer, and it had tons of crap inside, in big chunks that looked kinda like fur.....almost like a mouse hit a fan and exploded(without any mouse chunks of course). the stuff stained the front of my shirt when i picked the tower up to move it so I could install the new parts he bought. It was kinda blueish in color on my shirt.
Edit: Pfft, I said "it works better that the canned air", I had to fix it.
Message edited by cliffro on 06-08-2009 at 03:09:16 PM
------------------------------ Intel Xeon E3110@3.4ghz/GA-P35-DS3L/4gigs DDR2-800(@756)/EVGA GTX 260 Core 216 55nm
/2xSeagate 320 1x160/Corsair 850 TX/21" Dell P1130 & M781s/ Vista Ult. 64 SP1
Reply to cliffro
Like cliffro said an air compressor does work better. I personally take my computer's to the tire shop, I bought some tire's from the dude so he's cool with it.
Reply to starams5
Tom's Hardware > Forum > CPU & Components > Other Components > PC cleaning problem
There are 923 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
