Hard drive problems
Last response: in Storage
Open up Explorer, right-click on the drive and select "Properties".
Look at the "File System" type on the "General" tab. Is the File System "NTFS"?
If it's one of the FAT variants then it can't accept files larger than 4GB.
thanks guys i almost got there, i used the link then went through the motions to convert but it ended in saying insufficiant memory? it is a verbatim 1tr and has 862 GB free space on there.. confused is an understatement...
Related ressources
pjmelect said:
Probably the drive has been formatted FAT32 you should convert the drive to NTFS. It is easy to convert to NTFS but you can't convert back to FAT32.
See this Microsoft web page on how to convert.
http://support.microsoft.com/kb/307881
I'm not an expert on the conversion process, but it may be that your existing volume has some files or bad sectors located in areas that would be reserved under NTFS and this is preventing the conversion.
Do you have another drive of about 200GB or so? If you do, you can copy all your files to that drive, reformat your entire 1TB drive from scratch as NTFS, and then copy the files back again.
Edit - yes, I see that's what the pjmelect's link suggests. Try chkdsk first, and if that doesn't work you'll have to do the copy to another disk.
Ask the community
