Help finding 3.5 enclosure w/ big power supply (do I need one?)
Last response: in Storage
Hello,
While researching enclosures I came accross one possibility that reviewers indicated had a weak power supply. The enclosure is a Macally G-S350SUA & specs indicate it has a 2A power supply. Maybe it's just poor quality, right?
The thing is, I checked into my hdd's power requirements, and "Spin-up Current (Max.)" is listed as 2.2A:
http://www.samsung.com/global/business/hdd/productmodel...
(1TB Samsung 7200 sata, model HD103SJ)
Even though that's max, I thought "I guess I'll be looking for an enclosure with a beefier power supply"...to be safe.
But I can't find any.
Suggestions? A "toaster" or docking station would be fine too - actually preferable, IF it's good quality.
much thanks in advance for any help!
Ask the community
