USB 2.0 PROBLEMS
Forum Motherboards & Memory : General Motherboard - USB 2.0 PROBLEMS
:hello:
My mobo is ASUS M2N-MX SE
OS Win XP pro sp3
most of the time when i plug in something to a USB port i get the error on the bottom right of screen stating that this device is only using USB 1.0 when I know that all of my devices are 2.0, sometimes the device works fine. i don't know how to fix this. I don't Know what to do when it asks me to click on the balloon and select an available port. Please Help
Regards
Bernie
Sponsored Links
Front and rear ports or just one or the other?
If it is front and rear reinstall all the mother board drivers especially chipset and usb drivers.
Reply to daship
it is both front & Rear
I will reload the drivers tonight
Reply to berniemansell
Check the bios settings.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
I have checked the Bios Settings everything is ok! in the bios. This problem happens most of the time when i dont have the usb plugged into the computer when i turn the computer on.
When the computer is running i insert a USB 2.0 stick and 1/2 of the time it will say it is not running at 2.0, I have used all of the other USB ports, and found out that this problem does not only happen with the front USB ports but also the Ports attached to my MOBO at the rear.
------------------------------ AMD6000+ 64 AM2,
Windows 7 Ultimate 64bit, Gigabyte M61PME-S2P, 4GB DDR2 800, GIGABYTE 9600GT 512MB, 500GB SATA, 250GB SATA, 1.5TB EXTERNAL SATA/USB,17"LCD, 42" PLASMA, 660WATT 6.1 Surround Sound, 420watt PSU.
now my USB portable HDD stops working after about 10min of operation due to the USB error. I am planning on buying a new Mobo soon so i hope that this will solve the problem.
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > USB 2.0 PROBLEMS
There are 524 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
