OK guys heres a bit of background info before i go into my new build.
around 2-3 years ago i built a HTPC zalman HD160 case, Pentium D 2.66 O/C 3.5, 2GB ram, Asus P5W DH Deluxe Mobo, Zalman PSU. This pc is still working flawlessly, but can only have 3 hard drives running safely due to heat.
So now its time for me to build another pc but i will still be keeping my HTPC running to dont want to strip it down or jus do a case transplant.
The new PC will Need 8+ sata connections on the mobo and i just dont know if i really need to go for the i7 or if i should stick with a core 2 quad.
Also not sure on my psu if 550watts will be fine or if i need to go upto 800watts.
I definatly want a cpu that can be overclocked and will need a better cpu heatsink+fan.
The pc will mainly be used for storage playin/encodin music and video and lots of heavy downloading. I wont be playing any games always use my ps3 an 360 for that.
All parts need to be availble on www.scan.co.uk
the case gpu and harddrives i already have purchased and i want to stick with the gigabyte psu just not sure which wattage to get. Also if possible want to run it on a gigabyte mobo.
ok so here is what i have got so far
CASE
CoolerMaster Stacker RC-832 V2 Black Tower/Black Trim Case w/o PSU
CPU
Intel i7 920, Socket 1366 (B), Nehalem, 2.66GHz, Cache 8MB, OEM
Noctua NH-U12P SE1366 Exclusive Dual Fan CPU Cooler, LGA1366 only
GPU
512MB Gigabyte HD 4670, PCI-E 2.0(x16), 2000MHz GDDR3, GPU 750MHz, 320 Cores, D-Sub/ DL DVI-I/ HDMI
HDD
1x 74GB WD Raptor
6x 1TB Samsung Spinpoint
1x 2TB ????
Motherboard
Gigabyte GA-EX58-UD5, Intel X58, Sok 1366, PCI-E 2.0, DDR3 1066/1600/2000, SATA II, ATX
Optical Drive
LG GGW-H20L Super Multi Blu-Ray Writer & HD ROM Black L/S SATA & Cyberlink BD & HD Software *Oem
PSU
500W or 800W Gigabyte ODIN Pro PSU Modular 80%+ Eff' ???
RAM
3GB (3x1GB) CorsairXMS3, DDR3 PC3-10666 (1333) 240 Pin, Non-ECC Unbuffered, CAS 9-9-9-24
CASE
CPU
GPU
HDD
1x 74GB WD Raptor
1x 2TB ????
Motherboard
Optical Drive
PSU
RAM
