Hi
I just bought a 32in vizio flat screen, and im
temporary using a s-video cable to connect it to my 9800GT, but i cant change the resolution any higher than 1024x 768 in display properties and in the nvida Control Panel i have the same issue. Ive tried creating a custom resolution through the nvidia control panel but the test keeps failing.
is there any way other way to increase my resolution? and when i get a dvi to hdmi cable will the resolution remain the same?
the resolution for the tv is 1366 x768
For anybody with the same problem.
Found a long term temporary solution. Bought a $3 vga cable to connect to and now 1024 x 768 looks crisp, and I now have the choice to increase it to the tv's factory preset PC resolutions.
