About a week ago I posted that my new build nothing would start up except the power supply fans. Well I got a new power supply and now it will try to turn the cpu fan and case fan will just spin for a second then nothing else happens.
if you have a 6 or eight pin conector on you motherboard, make sure its pluged in right and then make sure you have the right conector pluged in there. ( I had the same problem and with out looking i pluged a eight pin conector in and turn out it was a pci-e cable with the additional 2 pins for eight pin setup and this caused what you are describing to me?
you have a short somewhere. when you turn the power on to boot the system and everything turn on for a second then shuts of its usally the ps going bad. in this case its a short (check your wiring)
i figured it out it is a grounding issue in the case.
I have the mobo as brass/mobo/brass.
People are telling me it's supposed to be brass/mobo/phillips
