Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > [Solved] ATX 12v Connector problems
Forum Motherboards & Memory : General Motherboard - [Solved] ATX 12v Connector problems
Best answer from shortstuff_mt.
Just got an ASUS P5Q Deluxe for a system rebuild, the board has an 8pin connector for 12v ATX, however the supply I have only has a 4pin P4 connector for 12v ATX. The MOBO manual says it needs a v2 ATX supply, and the box says the supply is v2.3, so I figured it would work. Will the 4 pin suffice or do I need a new supply with an 8 pin connector?
Cheers
Message edited by bob6k on 08-13-2009 at 06:44:46 PM
The P5Q Deluxe comes with a cover over 4 pins on the 8-pin connector. The 4-pin plug from your PSU will work just fine. Just leave the cover in place and plug the 4-pin connector into the 4 pins closest to the CPU socket.
Sponsored Links
Best answer
Reply to shortstuff_mt
Nope, no cover on mine, but I checked some pics online and you're right, it is supposed to have one, thanks for the help
Reply to bob6k
There are 521 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
