Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound Blaster X-Fi Surround 5.1 Buzz Noise
Forum CPU & Components : Sound Cards - Sound Blaster X-Fi Surround 5.1 Buzz Noise
Guys,
I'm having a big issue here and your help will be highly appreciated!
I just built my rig with a GIGABYTE MA790GP-UD4H motherboard. There was obvious buzz noises from the speaker whenever the system playback sound (no matter what system sound, music, movie or games). I'm sure it's not the speaker's problem as it's completely quiet when nothing is played and it works fine on my laptop.
So I thought it was the issue of the motherboard's onboard card. Then I purchased a Sound Blaster X-Fi Surround 5.1 USB card, installed drivers and the problem still exists.
This really surprise me as the Sound Blaster X-Fi Surround 5.1 is connected through USB and is far away from the case so I assume none of the PSU, video card and other signal would influcence the card?
I'm using Windows 7 RC and installed Creative's Windows 7 Beta driver.
This is driving me crazy. Please kindly help!!!
Sponsored Links
Try muting the auxillary and cd in. Also the TAD if you're not using it.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
I have a very similar setup... I have a rampage 2 extreme with the creative x-fi riser that came standard. I get a very "tin"y noise from mine intermittenly. I found that the best way to eliminate this was to uninstall and reinstall the drivers for the card. I completely removed all creative software and just let windows handle the installation and it worked out great. On the downside I have yet to coax anything greater than 2.1 out of mine even thought I am using a fiber optic cable. Please let me know if this works for you and what ultimately solves the problem.
Reply to sumofugu
There are 1058 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
