I've seen corsair h50s modded with reservoirs. I've even seen one with a 240mm radiator. Yet no one has tried to see what would happen if you added the 120mm, 240mm and a vga block all in 1 loop. Everyone sort of assumes it won't work.
Well curiosity has gotten the better of me and i've decided to try it. I ordered a Black Ice GT stealth 240mm radiator already but was just looking to get a few opinions on some other things before I got started.
1. I would like to try adding the 240mm rad first and if it's successful, add the gpu block. But what signs do water pumps give before they fail?
2. When picking a gpu block, is it better to get a full plate or a simple gpu block and heatsinks for the memory. I'm assuming a simple block will be easier to port to new hardware while a full plate will cool better. What are your thoughts on the subject.
3. What additives vs. pre mixed liquids. which do you prefer? Personally I don't care about color I just want to keep stuff from growing inside my loop.
