hello.
so i found this site a few weeks ago and its helped out tremendously. i have been trying to research everything i can on overclocking. and i came across an older post that had alot of info about overclocking the i5's. the one trouble i had with it was he was using a different MOBO then i was. and when i went into the bios just to look around and plan it all out i found out that my bios was a lil different. im running the the i5-760 on a MSI p55 gd80 mobo. now its been a while since i looked this stuff up and i could have sworn that if you OC your cpu, you had to OC your RAM as well. if so then the type of ram i have is cosair xms3 ddr3 4gb 1600MHz.
im not looking for a crazy overclock. just around 3.6GHz to 3.8GHz. i know this is pretty noob of me, but id rather learn how to do it through bios instead of the lame OC genie button that comes with the motherboard. any information would be awesome. im not asking you to hold my hand. but....ok well yes. im asking to you hold my hand and help me what to do. thanks for you time and i hope to hear from you guys soon
LK
LK
