1) you can use Everest Ultimate to monitor CPU temps, CPU usage, GPU temps, GPU usage, Fan speeds, HDD temps .... etc. It works on all hardware (ATI/Nvidia, AMD/Intel...)
2) or you can use GPU-Z to monitor everything about your Graphic card only.
3) there are a lot of other software available that will do the job.
------------------------------AMD Phenom II 940 OC @ 3.6 Ghz, 1.43V(cooled by Zalman CNPS9700-NT)
Gigabyte MA790X-UD4 (SB750); Corsair 2x2GB 1066Mhz 5-5-5-15 HDD Samsung SpinPoint F1 1TB; HDD Seagate Baracuda 7200.10 250GB;
LG DVD-RW; ATI Radeon HD 4870 @ 850/4200 Mhz; 22"LCD;
Reply to yonef
^ I dled everst, but it has some issues:
1. It's only trial version and doesn't give me 50% of the info in the main screen
2. You need to open the entire program to see the specs - whereas I'm looking for a tool
that can monitor your system settings on a sidebar. (ie. Rivatuner temperature display at the bottom
toolbar, or Nvidia-sys-monitor's green info bar that can be displayed on the side)
Any other suggestions? I already have GPU-Z & CPU-Z, but neither has the sidebar option.
ATITool can do that as far as I know for the GPU side and Systool will do it for the CPU side although both have issues with some setups due to their age.
