9600Gt Power Supply Problem !!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - 9600Gt Power Supply Problem !!
Im getting a 9600gt but my power supply is CoolerMaster 350W . Is there any chance of working ??
Sponsored Links
It should be OK depending on the rest of your specs.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
if it's a proper cooler master psu (not those ones you get with the box) it should run fine, only problem would be if you have lots of harddrives, fans, etc.
Reply to blackwidow_rsa
No . you should get a new one that gives 450W or more
Reply to digital7
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > 9600Gt Power Supply Problem !!
There are 1088 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
