Tom's Hardware > Forum > CPU & Components > Sound Cards > Use of a 8 or 16x slot for a 1x sound card
Forum CPU & Components : Sound Cards - Use of a 8 or 16x slot for a 1x sound card
I am thinking about buying an ASUS PCI-e sound card. It is for a 1x PCI-e slot. If my 1x slots are in interence with the graphic card, I assume I can use either a 8x or 16x slot that is available. Only one 4890 graphic card is used. The 8x and 16x slot key seems correct. I assume the slot will drop to 1x data rate with the 1x audio card installed. Let me know where I am right or wrong. Thanks, Vince
Sponsored Links
Your right you should be able to just drop the card in and it should work.
Reply to JD45093
Thank you so much for your quick answer.
Reply to blayer2
There are 1392 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
