This is what I have currently...
|CPU|AMD Anthlon x2 4800+ @ 2.64
|MOBO|ASUS A8N-SLI Delux
|RAM|4GB, 4*1Gig OCZ Platinum DDR1
|GPU|EVGA Geforce GTX 260
|HDD|400GB Caviar SE16
|Sound|Audigy Z2
|PSU|Corsair CMPSU-750TX
|Case|XCLIO A380
|CPUCooling|Zalman CNPS 7000
|OS|Vista Ultimate 32 Bit
|Monitor| BenQ FP9G+
Most of my rig is very outdated. I really want to get into 64 bit, and kind of future proof my setup a bit. I figure now that AM3 and DDR3 are out now would be a good time. I can only spend $1,300. It seems everytime I go and buy comptuer parts I always find a better deal or a bigger upgrade for a low price increase and kick myself in the ass. So I figured I'd ask for help.
Obviously I need a new motherboard, and thusly new ram and a new cpu.
I was looking at the - ASUS M4A79T Deluxe - mobo on Newegg, seems like its the only AM3 mobo you can get from ASUS? I kind of want to stick with them as I've never had a problem with them.
ASUS M4A797 Deluxe -
For CPU, I don't think there is really any other option then the -AMD Phenom II X4 810-, unless it is worth the wait for the 910, or what ever is next.
AMD Phenom II X4 810 -
Prolly going to get this ram, x2 -
I'm deffinatly lost on a monitor. Mine is very old, and I want widescreen. I honestly don't know anything about monitors. I was looking at the -Samsung 2439bwx-. Its 5ms but has a really high resolution for the price. I've been told that 2ms is much better so I was looking at -Acer P243WAid-, and -ASUS MK241H-. I don't really want less then 1920x1200 resolution. But if there is something better withint the 200-280 dollar range....
Samsung 2439BWX -
ACER P243WAid -
ASUS MK241H -
I'm going to stick with the GPU and PSU I have, I think those are both decent. I will keep my old crappy HDD and get a -WD Velociraptor WD3000HLFS- to put my games, apps, and OS on. I deffintaly need more then 300GB that the velociraptor provides, so thats why I'm keeping mine. I was also thinking about scrapping the 10000 RPM idea, and just get a WD 1TB HDD, not sure though, its cheaper then the velociraptor, but I dont know how much of a difference that would make.
Velociraptor WD3000HLFS -
Western Digital Caviar Black WD1001FALS 1TB -
I think I would need a new CPU cooler, but I'm not even sure if this one would work with my CPU? I havn't really found any info in CPU coolers for that chip. I was looking at the -Zalman CNPS 9700 NT-.
Zalman CNPS 9700 NT -
And I NEED a new soundcound, mine has poor vista support and I keep getting crackling. I was looking at the -Creative Sound Blaster X-FI Titanimun Fratal1ty Pro- I normally wouldn't spend that much on a soundcard, but it comes with a free headset that usually costs 50 bucks, and my headset is uncomfortable and broken. So I think thats a great idea.
I really appreciate any help I know its a lot to read. I just want to futureproof my rig, save some money, and make sure everything is compatible. BTW I'm aware that Intel is better atm, and I'm not here to argue that fact, but AMD is cheaper and thats what I need right now.
