I just put together a water cooling system. I seem to always have a leak on one of the nossles coming from the threds of where the barb connects to the resivor. I tried 2 different nossles with no preval. I used the crome barbs and that leaked where it connects to the resivor. I had to lossen it with pliers. Then I used the Swiftechs barb which is plastic. And that seemed to have worked for a bit but with a couple of splaters of coolant at the bottom of the case. I'm getting tired of where it is leaking so I'm wondering if I can thread it with Nilon threads like you would use for pool pumps.
I guse it would help if I gave you the specs of the res. It's the Swiftech MCRES Micro Rev. 2 Small Form Factor.
http://www.frozencpu.com/products/8..._Reservoir_12_ID_and_38_ID.html?tl=g30c97s165
Thanks guys.
Thanks guys.
