Hi everyone!
I would like to think I know a little bit about computers, but this problem has me confounded. I built my first computer last fall with hardware from NewEgg and installed Windows XP on it. However, a gaming friend bought me a copy of Windows 7, as he thinks it will help me run games more smoothly.
Unfortunately, I have been unable to figure out how to install Windows 7 on my computer. I've formatted and reformatted PCs (and Macs) before without problem, but this one is perplexing to me: I restart my computer and go into the boot menu, and when I select boot from CD drive it takes me to a screen where it tells me to "press any key" to boot from CD, which I do, and then it proceeds to boot from the HD into XP. What?!
So, after having this happen a few times, I went into BIOS and removed my HD completely from bootable objects and turned them all to CD. I went into the boot menu again and went to boot from CD. It proceeded to boot from the HD. What?!
Here are my system specs:
EVGA 012-P3-1470-AR GeForce GTX 470 (Fermi) 1280MB 320-bit GDDR5 PCI Express
Intel Core i7-930 Bloomfield 2.8GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Desktop Processor
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
If any of you have any suggestions, I would greatly welcome them, as I am stumped.
Thank you in advance for your time.
