Yes No
Ads
Tom's Hardware > Forum > Overclocking > General Discussion > Temperature Problems
Forum Overclocking : General Discussion Temperature Problems
I just built my first computer and I have an i7 930. I was looking to overclock it from 2.8 ghz to 3.2 ghz. Before I made any changes, I downloaded Core Temp and Prime95 to test the current temperatures and this is where I ran into problems. My idle temperatures are around 45 C and my load temperatures in under 3 minutes of Prime95 were in the 80s. I would like to keep it below 75 C.
I am using the stock heatsink and fan that came with the i7. I figured maybe my temperatures were due to me messing up the already applied thermal compound on the heatsink. When I first installed it, I had to remove it again because I had the power cord for the fan in the wrong place.
Hoping this was the solution, I removed the old thermal compound and I applied this thermal compound: Xigmatek PTI G3606 http://www.newegg.com/Product/Prod [...] 835233030. This was the first time I applied thermal paste and I found various methods to applying it online, I ended up using the included spreader stick with the PTI and applied a thin layer across the CPU.
After booting up and running core temp, my idle temperatures are still around 45 C and I got the same result with Prime95, 80 C in just a few minutes.
Is this the best I can expect from the stock heatsink and fan? Am I applying the thermal compound incorrectly? Do you have any other solutions or ideas for my problem?
Thanks.
Message edited by SK138 on 10-08-2010 at 01:43:39 AM
Reply to SK138
That's the best you can expect with the stock heatsink.
On the two latest generation Intel CPU's, the stock heatsink is good enough to run at stock frequency or, perhaps, the highest you can go without increasing your CPU voltage.
Reply to jsc
The temps are quite high, you may have applied the wrong thermal paste qty.
Is your fan running at 100 % ?
Reply to 55Range
There are 1946 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Any news on the Thermaltake Water 2.0 Extreme Cooler?
By amuffin, 13 hours ago:
If it has anything to do with Thermaltake, it's a BAD IDEA.
Best offers
Top experts
