I have 2 WD 320gb HD's in a raid 0 setup, (non boot raid) when windows 7 loads it says it needs to scan the disk because of data corruption or something to that effect. Scans to 7% show some bad sectors and unreadable sectors than freezes the machine.
If I skip it and load windows the raid drives show up fine I can even click on the drive see my files, look at my pictures, but as soon as I get into copying or access large amounts of data or any program on there it causes the machine to freeze for 10 seconds unfreeze and freeze again for 10 seconds or so, kinda of this weird loop that goes on until I reboot. It will also cause my video card to crash if I let the looping go on.
Now if I try to use any kind of scan disk program or recovery program it does the whole freeze loop or just freezes the computer. So basically I have limited to no accessibility of data and cannot use anything to recover it because it freezes the machine if it tries..
Is there any other way of getting my data off of there? I take the raid is bad or one of the drives is bad. If I only load one drive I cannot read it to see if one of the drives is bad. or is the raid itself corrupted and if I erase the partition and redo the raid will the drives work and could I maybe recover the data from an erased partition if the drive or physically not bad?
