USB problem
Forum Motherboards & Memory : Asus - USB problem
i run window vista 64-bit i have all drivers installed i ran driver agent to make sure all drivers are updated . when i plug in a 2.0 usb device a window pops up with a list of hubs that will perform faster and tells me to pick one . there is no option to pick or anything any ideas
Sponsored Links
http://windowshelp.microsoft.com/W [...] 11033.mspx
http://windowshelp.microsoft.com/W [...] 81033.mspx
Notes
When connecting a device to a USB port on a USB hub, monitor, or other device that's plugged into your computer, ensure that the USB port has enough power to support your device. Smaller devices, such as USB flash drives and mice, and devices with their own power cords, such as printers, typically work properly when connected to an unpowered USB hub. Some devices that use more power, such as USB-powered scanners and web cameras, require a hub that has its own power cord to function properly. If a device doesn't work properly when connected to a hub, try connecting it directly to one of your computer's USB ports.
Devices that transfer large amounts of information, such as external hard disks, scanners, and video cameras, function best when connected to high-speed USB 2.0 ports. Some older computers may include only USB 1.x ports, or a mix of USB 1.x and 2.0 ports. If your device requires a high-speed port to function properly, check information provided by the manufacturer for your computer to ensure that the port you're using supports USB 2.0. If your computer includes only USB 1.x ports, you can add USB 2.0 ports by installing a USB 2.0 card inside your computer.
------------------------------ "To better understand why you need a personal computer, let's take a look at the pathetic mess you call your life."
Reply to badge
Tom's Hardware > Forum > Motherboards & Memory > Asus > USB problem
There are 1157 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
