I have a msi 870a-g54 mobo http://www.newegg.com/Product/Product.aspx?Item=N82E16813130275&cm_re=msi_870-_-13-130-275-_-Product and the corsair xms3 kit http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260.
I was experiencing 30 seconds freeze once in awhile so I search for some post here and found out it might be related to the rams. So First i set the timing 9-9-9-24-41-2T which I got from CPU-Z and the voltage to 1.662 with these setting I can boot into window fine. But if i try to change the dram frequency from 1333 to 1600 the computer will freeze on the window bootup screen. Please help if you know what the problem is. Thanks a lot.
