Yes No
Ads
Tom's Hardware > Forum > Overclocking > AMD > AMD 780G Chipset Overclock Help
Forum Overclocking : AMD AMD 780G Chipset Overclock Help
Hello,
Ok, i have an AMD 780G Chipset with an integrated Radeon Hd 3200. Ive seen a lot of people overclock these little things up to 90% gain and have them stable. Only problem is that i cant seem to find something to overclock mine with. Amd overdrive wont let me overclock with it. And no other video card overclocking software i can find will either. This is an acer aspire 5517. But that shouldn't matter because the chipset is unlocked for overclocking. Is there any combination of keys to unlock certain bios features on this thing? Any help would be apreciated.
Message edited by 4Ryan6 on 10-11-2010 at 04:25:40 PM
Reply to jwaldron1
The title of this topic has been edited by 4ryan6
More than likely there's a feature on auto that needs to be set to manual, it would help others to help you, by supplying the brand and model # of the M/B in question as there are a few M/Bs sporting the 780G chipset, and there will be BIOS differences between the brands.
Quote :
Since it's a laptop that does matter, the chipset may be unlocked for operating system overclocking but not manual BIOS overclocking.
Message edited by 4Ryan6 on 10-11-2010 at 04:35:55 PM
------------------------------ Cooling Fan Roundup
Thermal Compound Roundup
Reply to 4Ryan6
CPU Arch : 1 CPU - 2 Cores - 2 Threads
CPU PSN : AMD Athlon 64 X2 Dual-Core Processor TK-42
CPU EXT : MMX(+), 3DNow!(+), SSE (1, 2, 3), x86-64, AMD-V
CPUID : F.8.2 / Extended : F.68
CPU Cache : L1 : 2 x 64 / 2 x 64 KB - L2 : 2 x 512 KB
Core : (0 nm) / Stepping : ???
Freq : 1596.1 MHz (199.51 * 8)
MB Brand : Acer
MB Model : Aspire 5517
NB : AMD 780G rev 00
SB : AMD SB700 rev 00
GPU Type : ATI Radeon HD 3200 Graphics
GPU Clocks : Core 196 MHz / RAM 333 MHz
DirectX Version : 11.0
RAM : 4096 MB DDR2 Dual Channel
RAM Speed : 319.2 MHz (Unknown) @ 5-5-5-15
Slot 1 : 2048MB (5300)
Slot 1 Manufacturer : Kingston
Slot 2 : 2048MB (5300)
Slot 2 Manufacturer : Kingston
This is what i can get from CPU-Z Hope it helps
Reply to jwaldron1
There are 1931 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Any news on the Thermaltake Water 2.0 Extreme Cooler?
By amuffin, 14 hours ago:
If it has anything to do with Thermaltake, it's a BAD IDEA.
Best offers
Top experts
