Tom's Hardware > Forum > Motherboards & Memory > Memory > GSKILL 4GB (2x2GB) 1066 5-5-5-15
GSKILL 4GB (2x2GB) 1066 5-5-5-15 @ 2.1V Memory Problems
Forum Motherboards & Memory : Memory - GSKILL 4GB (2x2GB) 1066 5-5-5-15 @ 2.1V Memory Problems
Recently I purchased a set of memory in the topic, and it requires the user to tweak the settings in the BIOS because it can run better than the 800MHz JEDEC #2 standard. Mainly the changes involve setting the memory speed to 533MHz, and changing the voltage, and presumably the motherboard would have the other settings correct. However, upon doing this, I obtained errors usually resulting in a BSOD.
I even assumed that the motherboard was auto-setting the timings wrong, so I went back and changed the CL, etc. to their rated timings. Still wrong. So I was doing some more research today and I realized that the one setting I didn't check was the tRC.
Now presumably the memory settings this company rates the memory for are reflective of the EPP #1 standard. That requires a tRC of 48. However, when I attempt to change the setting in my motherboard, the maximum value is 42. Am I left stuck at the slower speed on my Asrock K10N78M motherboard?
Sponsored Links
There are 710 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
