Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] Help- Can I upgrade the CPU in my Satellite laptop?
Forum CPU & Components : CPUs - [Solved] Help- Can I upgrade the CPU in my Satellite laptop?
Best answer from Crashman.
I have a Toshiba Satellite model # 2455-S305 laptop. It has a ~2.6GHz Pentium4 CPU, 1GB Ram, etc. The FSB is at 533 MHz. I can supply more details if necessary.
I am an EE (Electrical/Electronic Engineer) with a lot of experience in general hardware and software, but, I do not have much experience with overclocking, CPU upgrades, CPU part numbers vs. performance and other specs, etc. I can design about anything which would be required for the question I am going to ask, but I need more information first, and I am a bit lost trying to wade through many thousands of "hits" on Google and others when I ask about upgrading the CPU to a more contemporary, up-to-date version for better performance.
So, that is my question: Can I upgrade the CPU in this laptop without replacing or heavily modifying the motherboard? I know the more obvious stuff: the socket must match the new CPU, the voltages must be right, etc. I am wondering if anyone has tried to put a newer CPU in this laptop, and would be willing to share their experience with me so I don't have to blunder through the process, only to discover after many hours of research that it can't be done because of [reasons].
You see, I am getting a bit "long in the tooth" (that is, old), I don't have very good eyesight, having lost vision in my "best" eye to a detached retina, leaving me "blind in one eye and can't see out t'other", and, on top of all that, I am inherently lazy. The last is probably the predominant reason I am writing to you here!
It wouldn't make sense to spend more than the cost of the new CPU plus a few bucks for miscellaneous parts, etc., as there are new laptops which would be roughly equal to this or better, in $500 price range, sometimes even lower if you accept a refurbished laptop. I don't want to spend that now, though; I want to try to "make do" with this Satellite until I save my pennies and can buy a workstation grade laptop with a larger, higher res screen, etc. So, if I can find a way to upgrade this "plain Jane" P4 to a multi-core with lotsa features, I would like to do that to get me by until later this year.
If you have any knowledge or experience with this or a similar situation, I sure would appreciate hearing from you. Even if it isn't with this particular laptop, I am sure the situation is the same for any brand, as it is the CPU which controls this question.
Thank you, in advance;
Larry
Toshiba used desktop processors in those fat notebook computers, so you can just pop in a Pentium 4 2.80 GHz with 533 MHz FSB, or a Pentium 4 3.06 GHz (not 3.00 GHz). It's an easy upgrade, but it's not much of a performance boost.
Sponsored Links
i would just wait, save the money (you won't see that much of a benefit from upgrading from a P4 to a P4 which is probably the only upgrade you have), and get a new laptop earlier
Reply to mindless728
You'll probably find more Toshiba Satellite owners over @ the Toshiba laptop forum: http://laptopforums.toshiba.com/tshb/
Or in the THG Laptops & Notebooks forum
I have a feeling that 72's advice hit the mark.
Reply to WR2
Best answer
Reply to Crashman
sounds like a nice doorstop lol. just playin
Reply to million3g
There are 1125 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
