Hello everyone this is my first post in TH,
I've saved enough money for a new rig from my part time job.
I'm thinking of building a decent gaming rig that will last me for the next five years. My maximum budget is $1500 CDN before S&H and Taxes.
I'm in Canada and a University student and I havent built a new computer in 5 years or so, I did a ton of research for these parts by reading reviews and looking at other peoples builds. My current computer has a P4 HT 3.0 GHZ But still plays my steam games allright but It feels like it's time to get renewed. I will be reusing the optical drive and also my soundblaster card from creative if it will support Vista. Also will put in a WiFi card from my old build.
I'm going for the i7 because I allways have more then 10 tabs open in Firefox and more then 4 Apps running at the same time. And I got programs that decode files in the background such as Winrar. I also have Documents open to as I need to work on them for school. Since the i7 has quad core seems like a no brainer and the reviews are great.
On the new build I will be installing Vista 64 bit builders edition. Might be interested in overclocking the CPU/GPU but not at the present. In the future might upgrade to SLI and also get more memory.
Here are the parts:
Case:
[strike]Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail [/strike]
NZXT Tempest EATX Mid Tower Case Black 3X5.25 1X3.5 8X3.5INT No PS Front USB Firewire Audio
PSU:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
CPU:
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
Motherboard:
ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Memory:
[strike]Patriot 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model PVT36G1333LLK - Retail [/strike]
OCZ Gold OCZ3G1600LV6GK 6GB DDR3 3X2GB DDR3-1600 PC3-12800 CL 8-8-8-24 Dual Channel Memory Kit
Harddrive:
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
GPU:
[strike]MSI N260GTX-T2D896-OCv2 GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail [/strike]
BFG GeForce GTX 280 602MHZ 1024MB 2.214GHZ GDDR3 PCI-E Dual DVI-I HDCP HDTV Out Video Card
[strike]
The total price before taxes and shipping and handling is: $1,515.43 CDN
There is also Mail in rebate in USD of 45$'s which is $57 CDN Which will bring my total back to $1458.43 CDN
[/strike]
Please let me know what I should replace or if there is anything wrong with my choice of hardware.
Also is it a good time to build a new pc in this time due to the recession? It seems that if I wait the prices will go down in less then a month instead of 6 months as I usually see them.
Looking forward to hear your thoughts and opinions.
Updated:
For those who are intrested I got it to $1,420.66 CAD after Mail in rebate.
Before mail in rebate it's $1,503.28 CAD
Shipping and handling is free. Paid $194.13 In taxes $22.07 for Shipping insurance.
and thus after that it's $1,697.41 before Mail in rebate or $1,614.79.
Thank you everyone
Here are the parts:
Case:
PSU:
CPU:
Motherboard:
Memory:
Harddrive:
GPU:
[strike]
[/strike]
Updated:
Thank you everyone
