Lately my liquid cooling system has been very noisy, I can hear it pumping the coolant, it gets louder and then quieter. Looking at it though I can see air bubbles in the coolant lines and I notice that instead of coolant moving in one direction(in one tube back out thru another) it's going back and forth in tubes - is this how its supposed to move? And the noise corresponds with the coolant flow - any ideas?? The CPu is not overheating the temp gauges are reading normal. I worry about the air bubbles - if air can get in can coolant get out????
The liquid should be moving in one direction, this is why I use an inline flow meter. If you don't have any leaks (re: air) your pump is failing, replace it ASAP.
Here are some flow meter's you can look at but I would stay away from the swivel nozzles, very awkward. The swivel nozzles are cool for stationary part only in my opinion.
