Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Front panel SOLID HEADER USB connector.
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Front panel SOLID HEADER USB connector.
I need the ONE PIECE header which is male on one side and female on the other. I am then able to connect my loose front panel USB wires to this ONE PIECE solid header block and then insert the ONE PIECE solid header block onto the appropriate pin header on the mother board. I have come across these in some of my motherboard accessories but I absolutely cannot find them online. Help if possible.
Sponsored Links
You're basically talking about a male and female port stuck together? Sorry, it's not entirely clear what you're talking about.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
- 0 +
You are referring to ASUS's Q-Connect. Those can be bought separately on places like eBay.
Since the pin order of USB headers are universal among motherboard I used super-glue to carefully align the individual one-pin header side by side and stick them together.
------------------------------ GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
http://farm3.static.flickr.com/2520/3850950213_aea6bbbcfe_o.jpg
Reply to wuzy
- 0 +
http://estore.asus.com/shop/item.asp?itemid=3561
The blue one is USB, the red is firewire and the white is for the power/reset/speaker/HDD
Reply to ausch30
Yep...the Q-connectors...came with my ASUS motherboards. I wish someone made a generic version. Just 10 pins male/female. Don't need color coding. Can use it for USB/Firewire and many front panel motherboards have the same pin layout for RESET/POWER/POWER LED/HD/SPEAKER.
Thanks for your help everybody........I'll keep looking. Maybe contact some Chinese manufacturers, see if they can't produce some for us.
Reply to kleankutken
I just built a gaming PC using an XFX nForce 750i motherboard and a Cooler Master Storm SCOUT case. Strangely enough, in this day and age, that 750i motherboard only has one USB 10-pin (#9 vacant) Header, and the SCOUT case has two female USB 10-pin cables, (with #9 plugged) coming from the four USB port Front Panel. Thinking that I could find some kind adapter easily, I drove myself crazy searching for two weeks, and was just about ready to try to invent one, when I stumbled across a solution. I found one PCI card on the market with a USB internal Header: http://www.newegg.com/Product/Prod [...] 6815201008 AND it is only $7.99 :wahoo:
If you are just needing a USB Header Extension, here is one for $8.99: http://www.ask.com/bar?q=USB+heade [...] id%3D22079
What would be IDEAL, is some kind of adapter that would convert the single USB Header on the motherboard to 3 or 4 headers, but I failed to find such a device, NOR did I find a PCI card with two USB Headers on them. I do not have room for a second PCI card, so my plans to purchase this Floppy/Card Reader/USB, went down the tube, because I find no way to hook up a third USB female header: http://www.tigerdirect.ca/applicat [...] &CatId=630
DC
Reply to DC-Scout-67
There are 542 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 -pcaddict- won the Freshman badge
  • 01:00 impreza won the Freshman badge
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
