can I swap a 220 power supply from Philippines with a 110 for use in the Unites States as long as it is the same wattage i.e. 500 Watt 220 is currently installed.
Sponsored Links
Hi D
I don't see why not as long as it has a voltage input switch for 220v and 110v. The Hz varies from Country to Country so you might want to check that as well, however, most PSU's have a Hz range that will cover most Countries, example 47-63Hz
Message edited by starams5 on 06-07-2009 at 11:05:18 PM
Reply to starams5
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
The input voltage is the same for the Philippines as the United States, 110v and 220v.
http://www.aglobalworld.com/intern [...] oltage.php
Message edited by starams5 on 06-08-2009 at 09:15:47 AM
Reply to starams5
yea should work just based off that anyway
Reply to million3g
- 0 +
What make / model PSU do you currently have?
Reply to croc
Most newer PSU's will automatically detect and set themselves for 220 or 110, whatever you plug them into.
If it does not have a switch on the back, it is an auto-adjust.
But, just to be certain, what exactly is the brand and model?
Pluggin in a PSU set for 220 into 110 will result in the PSU simply running way under power, if it runs at all.
Plugging a PSU set for 110 into 220 will kill it instantly.
Reply to jitpublisher
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Swap 220 power supply for 110
There are 1351 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
