What is the difference between a cd drive and dvd drive
Hello,what is the difference between cd drive and dvd drive
5 answers Last reply
More about what difference drive drive
  1. A CD Drive plays and sometimes records on the CD Format while DVD plays CD and DVD and generally burns to both.
  2. A CD drive just reads CD disks and a DVD drive reads CD and DVD disks.
  3. Quote:
    Mod's please enter this in the "stupidest posts/threads of the year" drawing. If you don't know the difference between a cd and a dvd, you should not be anywhere near a computer.
    Not everyone is on the same knowledge level. It's a valid question. Let's try not to make people feel bad.
    +1^
  5. It's totally understandable for the uninitiated to confuse the two since the drives look identical and so does the media.
    CD ("Compact Disc") was created in the 1980's for music - these discs can hold about an hour of music or about 650MBytes of data.
    DVD ("Digital Video Disc" or "Digital Versatile Disk" depending on who you talk to) was created in the 1990's for video. These disks can hold about 2 hours of video or about 4700MBytes (4.7GBytes) of data. They also come in "dual layer" versions that hold almost 9000MBytes (9GBytes) of data.
    The oldest drives handle CDs but not DVDs.
    Newer drives that handle DVDs are almost always backward compatible and work with CDs as well.
    Drives that handle CDs will have the CD logo on them somewhere:
    Drives that handle DVDs will have the DVD logo:
    In addition to drives that read CDs and/or DVDs, there are drives that can "burn" (write data to) special blank CD and/or DVD discs. You generally need special software to do this (it usually comes with the drive) and there are a bunch of rules for how to do it depending on what kind of media you use and whether you want to play/view the disc on a standard consumer CD or DVD player.
DVD Drives DVD CD Drives Storage
