Water cooling an i7 and a gtx 295
Hello everyone, very helpfull people all around this site so i thought i would ask here
Basically, i am wanting to water cool my asus engtx295 and my intel i7 920 mainly just for the noise and temperatures, but also so i can safely push the i7 a little bit with a stable overclock if possible. I have a little and very basic understanding of both overclocking a CPU and watercooling hardware components so please excuse me if i am a little slow with things and the processes involed. Ideally what i am after is a water cooling system capable of cooling both CPU and GPU and possibly in the near future another gtx 295.
Here is the specs of my system as of now:
Intel i7 920
Asus ENGTX295
Corsair 850watt PSU
Storm Sniper Case
4GB Ocz Gold DDR3 RAM
Thanks in advance
John
Intel i7 920
Asus ENGTX295
Corsair 850watt PSU
Storm Sniper Case
Thanks in advance
John
More about : water cooling gtx 295
It is very important that you expand your knowledge beyond just" little and very basic understanding of watercooling",it would make thinks alot easier for you and us. Start with sticky's ,read little watercooling related forums ,for some it takes few hours or months for others,here are few good places to start:
http://www.overclockers.com/forums/showthread.php?t=628...
http://www.xtremesystems.org/forums/showthread.php?t=20...
Related ressources
- P6T quad SLI GTX 295 with Koolance VID-NX 295 water blocks - Forum
- Liquid Cooling a GTX 295 - Forum
- I7 975 Extreme Edition in ASUS Rampage II Extreme with dual GTX 295 's - Forum
- Water Cooling an i7 option? - Forum
- TH Water Cooling Club and Picture Gallery - Forum
Ok thanks mate, i have been doing a little last night and today and i have got a better understanding now, not enough to be in a position to buy things but enough to know the majority of what i need.
I have been having a look at this: http://www.anglianinternet.co.uk/acatalog/info_MDD027.h...
Do you have any insight as to how good it will perform?
Koolance have been around for some time now and yes they did get in trouble for using aluminium and later acrylics in some parts but i think the company is on the rebound, Koolance CPU-360 , Rev1.2 (universal) is one of the top rated blocks right now .There is a group of people that are strictly in to performance and there are some that appreciate well machined manifold (coming from a guy that machine parts for living),the more competition the better for costumer ,here is old thread with some nice blocks ,Aquacomputer cuplex XT di is example :
http://www.overclock.net/water-cooling/749693-review-22...
if i'm going to spend 70-100$ for cpu water block it better be solid and nicely machined, compared to cheap plastic/sheet metal assembly
rofl_my_waffle said:
Im going to replace my radiator with the new Feser Admiral line that is available later this month. Will comment later.I also have a bottle of the Ice Dragon zinc oxide nano fluid. Will use that when I get my radiator.
who you buying from ,last time i check they were all sold out ?
Hey again, been having a serious research and look around on the net but i have one question still, say if i was cooling 2 cards and the cpu, how do i run the chain? Would it be better to use a splitter, like a "Y" from the radiator with one tubing feeding the cpu and another running throught the two cards and then back to another Y splitter before reaching the next part.
nissanlover said:
Hey again, been having a serious research and look around on the net but i have one question still, say if i was cooling 2 cards and the cpu, how do i run the chain? Would it be better to use a splitter, like a "Y" from the radiator with one tubing feeding the cpu and another running throught the two cards and then back to another Y splitter before reaching the next part.Yes you could use "y" splitter i have seen it done (don't know if that will improve anything but it's worth a try ),"running throught the two cards and then back to another Y splitter before reaching the next part"-how about..avoid second splitter and run strait to rad/res.,if you want to run single loop i suggest large res.
here is brand new res. from koolance (not that big but worth mention);
http://www.xtremesystems.org/forums/showthread.php?t=26...
http://www.koolance.com/water-cooling/product_info.php?...
"how do i run the chain?"--res=>pump=>cpu=>gpu=>gpu=>rad
single or dual loop...it's your call
P.S.
you be fine if you cool just one card(top of sli/cross)
Run them serial, not as parallel. You will lose the head pressure when you split out the 'Y' and not get the flows you want. It's best to keep each loop in serial, if you don't want that, run dual loops.
As long as you have good flow and enough radiator to cool your components, you only need a single loop. Multiple loops are for easier management (if you swap/bench cards or CPUs) and can offer better flow rates, but it depends on how you pair your radiators.
rubix_1011 said:
^^ ?????????Only put one card in a water loop and leave the other air cooled? You could...I suppose...it technically wouldn't make a difference unless the air cooled card wasn't getting good airflow (which could be the heat question to begin with).
some motherboards have very close PCI spacing/no air flow but the bottom card should have plenty of air to keep the temps under control on it's own with good case air flow
Thanks for the tip off about th RP-459X2, really really like it and am leaning towards almost definatly. How well does it perform and any idea on the amount of noise? Also, i noticed it has 2 ins and 2 outs being p1 and p2, does that mean i would be able to run p1 out to cpu and p2 out to gpu? sorry if this is a dumb question lol
nissanlover said:
Thanks for the tip off about th RP-459X2, really really like it and am leaning towards almost definatly. How well does it perform and any idea on the amount of noise? Also, i noticed it has 2 ins and 2 outs being p1 and p2, does that mean i would be able to run p1 out to cpu and p2 out to gpu? sorry if this is a dumb question lolYes you can do that,you can run single loop with just one pump+acetal plug or run two loops with addition of 2nd pump on the same res-just little weird
"It's intended to run either a single pump, or else two pumps in parallel loops"-read the link to XS above
This is new product i would wait for some professional reviews before i buy
Related ressources:
- ForumBuying a water cooled i7 pc for gaming
- ForumFOR SALE 2 evga gtx 295 's co-op with koolance water blocks with boxes
- ForumHD 5970 over GTX 295 ?
- ForumGTX 295 vs 2x GTX 285 in SLI
- ForumGTX 295 temperatures w/ backplate (disappointing results)
- ForumGTX295 Windows7 64-bit SLI enable problem
- ForumCan I SLi 2 diff model GTX 295 's
- ForumWill the GTX 295 work fully with the P5Q-Pro?
- ForumXFX GTX295 Very low score on Vantage
- ForumHd4870x2 & gtx 295 performance issues
- ForumWater Cooling Help!!!!!
- ForumJust took the plunge and ordered a water cooling system
- ForumWhat is the best water cooling system for tri sli
- ForumFixed Voltage
- More resources
Read discussions in other Overclocking categories
