Tom's Hardware > Forum > CPU & Components > Network Interface Cards > Network Controller n Audio device are missing?
Forum CPU & Components : Network Interface Cards - Network Controller n Audio device are missing?
Hi there,
today i reinstall my window, after installation when i go for install the drivers , i found Network controller and audio device is missing.
then i check BIOS
in Bios setting both are hidden
i can't enable both device from Bios and OS
i do not what can i do
help me please.
Dan
Sponsored Links
Hi D
Are these onboard devices or PCI?
Reply to starams5
yes both are on board devices
Reply to danhull
Hmm.....strange. Try this: Shut down and unplug the PSU. Remove the mem sticks and the CMOS battery. Discharge the motherboard by holding in the power button while touching the chassis for approx 30 sec. Put the battery back in followed by the memory then post, see if that helps.
Reply to starams5
I would recommend you update the BIOS to latest first. Then perform a 'Reset to Default' afterward in BIOS. Reboot then try again.
Are you sure you've looked in every sub(or sub-sub) menus in the BIOS?
Message quoted 1 times
Message edited by wuzy on 06-09-2009 at 04:29:22 AM
------------------------------ GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
http://farm3.static.flickr.com/2520/3850950213_aea6bbbcfe_o.jpg
Reply to wuzy
That was going to be my next reply, his bios maybe corrupt. I wanted to try this first.
Reply to starams5
Thx to Wuzy and staram5
its works reset default BIOS Settings
Reply to danhull
GOD bless u many many thx to all
Reply to danhull
Glad every thing worked out, take care.
Message edited by starams5 on 06-09-2009 at 05:03:02 AM
Reply to starams5
*records another 'Reset to Default' success*
Funny that it works for some BIOS. I happen to came across it back in the old days with my 8RDA+ after updating the BIOS. There were supposed to be new options in BIOS, but I didn't see them. Then I read instruction that suggest with any newly updated BIOS you need to reconfigure everything from ground zero with 'Reset to Default'.
Anyway, glad you've fixed it.
Reply to wuzy
@wuzy
"I would recommend you update the BIOS to latest first. Then perform a 'Reset to Default' afterward in BIOS. "
Don't try to steal all the credit, you recommended "Reset to Default" after the bios update. Sorry buddy but you have to share this one :D.
Reply to starams5
There are 1291 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
