will a 850w ps draw more than a 750w ps under the same load?
Sponsored Links
the only difference is if the have different efficiencies at that load level
Reply to mindless728
The answer to your question is no. As mindless728 already pointed, there could be a little bit of difference if the two psu's operate at different efficiency levels for the same load. The newer high quality psu's operate at high efficiency levels across a wide range of operating loads.
Unfortunately there are still a lot of cheap, inefficient, psu's of questionable quality and performance being manufactured.
Reply to JohnnyLucky
- 0 +
thanks so much for helpfull reply, exactly the answer i was looking for
Reply to bigkid
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power draw
There are 510 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
