Tom's Hardware > Forum > Graphic & Displays > Nvidia > GeForce 260 Sound Issues
Forum Graphic & Displays : Nvidia - GeForce 260 Sound Issues
I have been trying to get my GeForce 260 to run for 3 days now. EVGA and Asus keep pushing me off to the other. I can get the card to run but I can not get any sound from it, either thru an HDMI cable or thru a SPDF connection. I have downloaded Realtek drivers but that hasn't helped either.
Does anyone have any ideas?
Message edited by Anonymous on 04-01-2009 at 06:49:34 PM
Sponsored Links
Just use the standard analog connections to the mobo; i still don't see the point of trying to route sound through a GFX card, especially considering SPdifs issues beyond 2.0 sound...
Reply to gamerk316
I have tried doing that. As long as the mobo recognizes the card it will no allow sound thru analog connection. There is a Spdf out on the mobo that Nvidia says to hookup but Asus says different. Either way it is connected, it still won't produce sound.
Reply to Anonymous
Whats the default sound output device in the Control Panel?
Reply to gamerk316
If you hook the sound through the SPDIF you need to select as playback device from the control panel "SOUND" option. The audio will divert the output to the SPDIF port. That should enable you to get the sound through the video card.
Reply to leon2006
There are 1138 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
